Message 51 of 78
Re: Broadband Ininity - change in service?
Ah thanks for comments @licquorice / @pippincp - our line can handle up to 28 apparently, so Infinity 1 would be the better package for us as I understand it, as the cap for that is 50 - which we will never reach on this line.  At least that's what I think he was saying - but good to know that being on 2 isn't causing any issue
Message 52 of 78
55 actually, but yes, Infinity1 would be better if at a better price (which might not necessarily be the case)
Message 53 of 78
I can't actually tell what the price difference is , if any,  as there isn't a "downgrade" option on my account info - but I'm sure it will get sorted once the fault is finally closed
Recognised Expert
Message 54 of 78
@pippincp @licquorice @cjmole
My mistake I apolgise!
I missed the part about the VDSL Modem.
Smiley Sad
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Sage
Message 55 of 78
That's OK, we know you are learning.Smiley LOL
None of us are innocent, we have all made and continue to make mistakes occasionally. We are only human after all.Smiley LOLSmiley LOLSmiley LOL
Message 56 of 78
@PaddyBwrote:
Hi @cjmole,
Thank you for posting back following that visit. I've ran a few checks on your connection and its still picking up a few errors on the line. I reported this back to BT Wholesale, I'll get back in touch with you tomorrow as soon as I have an update.
PaddyB
@PaddyBI've not heard anything further Paddy, have you?  The connect remains good, and far as I can tell this end all seems good - but you said they were still seeing a fault?  Could you investigate for me please whether it would be cheaper for us to be on Infinity 1 as suggested? I can't find a price anywhere for a downgrade
Thanks 🙂
Message 57 of 78
Update - the engineer came, ripped out a whole load of dodgy backwiring and all was well for about a week.  Downgraded our package to infinity 1 and that went live last night.  Over the last 24 hours we've had connection drop a few times - should I be concerned?  I wonder if its the switchover to Infinity 1.  Was so pleased that it looked like finally we had beaten the fault but now I'm not 100% sure again Smiley Frustrated
@PaddyB@DanielS@RobbieMac
Moderator
Moderator
Message 58 of 78
Hi @cjmole
Thanks for posting back!
The drops may well be related to the swithover.  Can you keep an eye on things over the next few days and if it's still happening I can look at it for you again if needs be?
Cheers,
Robbie
Message 59 of 78
Will do @RobbieMac, thanks - I'm hoping it's just a glitch as it was perfect leading up to the switchover!
Message 60 of 78
Happy to report that all seems stable for the last week, I think we can finally relax
Thank you to all involved that have helped us solve our problem, in particular the mod team who went that extra mile for us 🙂👏  @RobbieMac please pass on my thanks
