PavlosUK
Message 1 of 6
Broadband Keeps dropping
started last night and has dropped about 30 times in total
ive done a landline test which is fine and have also tried the test socket but that also failed
i spoke to live help and she said it looks good but will refresh things her end but its still playing up
dont know what to do now
5 REPLIES 5
Message 2 of 6
Re: Broadband Keeps dropping
Helpdesk will just do rnot set but you can try a factory reset using the recessed button on back and holding until lights flash
remember turn of smart setup and split wireless networks
PavlosUK
Message 3 of 6
how do i turn off smart setup and split?
Message 4 of 6
Techwizz
Message 5 of 6
Surprised no one has asked this, but are you connecting via a wireless or wired connection?
Moderator
Moderator
Message 6 of 6
Hi @PavlosUK  did you manage to follow the suggestions by @Keith_Beddoe  and has this resolved the issue?
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
