JamesPlatt_UK
Message 11 of 19
Re: Broadband Network Fault
Event log:
19:43:21, 27 Mar.
:HTTP UserAdmin login from 192.168.1.171 successfully
19:42:54, 27 Mar.
:DHCP Confirmation of Request
19:42:48, 27 Mar.
19:42:46, 27 Mar.
wl1.1:A WiFi device <8C:83:E1:DE:16:AE> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_REDSIDE_O1_2G])
19:26:48, 27 Mar.
: HTTP UserAdmin timeout from 192.168.1.171
19:17:10, 27 Mar.
BR_LAN:The DHCP options that are offered by the device (id:7): DiscoverOptions: 53,55,57,61,51,12 | DiscoverOption55: 1,121,3,6,15,119,252 | RequestOptions: 53,55,57,61,50,54,12 | RequestOption55: 1,121,3,6,15,119,252 | HostName: VictoriattsiPad | VendorId:
19:17:10, 27 Mar.
19:17:10, 27 Mar.
19:17:10, 27 Mar.
19:16:50, 27 Mar.
wl1:A WiFi device <08:E6:89:E8:E8:CB> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
19:16:38, 27 Mar.
19:15:15, 27 Mar.
:HTTP UserBasic login from 192.168.1.171 successfully
19:14:02, 27 Mar.
19:05:29, 27 Mar.
wl1:Device <BC:30:7D:49:32:C0> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
19:04:36, 27 Mar.
BR_LAN:The OIE is supported for the device (id:13)
19:04:36, 27 Mar.
BR_LAN:The DHCP options that are offered by the device (id:12): DiscoverOptions: 53,61,12,60,55 | DiscoverOption55: 1,3,6,15,31,33,43,44,46,47,119,121,249,252 | RequestOptions: 53,61,50,54,12,81,60,55 | RequestOption55: 1,3,6,15,31,33,43,44,46,47,119,121,249,252 | HostName: DESKTOP-0CGJ0P3 | VendorId: MSFT 5.0
19:04:36, 27 Mar.
19:04:29, 27 Mar.
BR_LAN:New device (id:13) connecting on the LAN was detected
19:04:29, 27 Mar.
wl1:A WiFi device <44:85:00:EE:74:C9> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
18:58:37, 27 Mar.
Sage
Sage
Message 12 of 19
Could you post the connection stats from the hub.
HH6 Advanced settings/technical log.
HH5 Troubleshooting/helpdesk.
brookheather
Message 13 of 19
@JamesPlatt_UKwrote:
Quiet line test:  Slight static between announcements but its a cordless hadset, nothing major.
Line test shouldn't have any static - you could have a line fault.  It would be best to perform the test again with a corded phone - it should be silent between announcements.
JamesPlatt_UK
Message 14 of 19
@pippincp@NeilO You can find full log here
https://drive.google.com/open?id=1nbBsTtPDpYMTRp-3HYgVq35goFpaDJEP
@brookheatherNo corded phone, will try and borrow one. I thought maybe just because cordless. Now you mention it a couple have people have said, when phoning BT support, that the line was bad, difficult to hear 🙂
Sage
Sage
Message 15 of 19
I don't want to see the log. I want to see the connection stats. Lines 1-12 will suffice.
JamesPlatt_UK
Message 16 of 19
@pippincp  @NeilO   @DanielS  Bit confused what connection stats means. There are 2 tabs under technical log, Information and event log. This is the information:
Product name:
BT Hub 6A
Firmware version:
SG4B1000B540
Firmware updated:
28-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 5 Hours 36 Minutes 58 Seconds
Data rate:
20.00 Mbps / 74.92 Mbps
Maximum data rate:
23627 / 77186
Noise margin:
9 dB / 4.3 dB
Line attenuation:
14.1 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Sage
Sage
Message 17 of 19
That's the information we wanted.
Connection time is only 5 1/2hrs is this due to a manual restart?
JamesPlatt_UK
Message 18 of 19
Yes I was trying a different router to see if made any difference.
JamesPlatt_UK
Message 19 of 19
Also get this errors in browser intermittently.
