JamesPlatt_UK
Message 1 of 19
Broadband Network Fault
We have experienced fluctuating broadband speeds for the last 2 weeks, despite having had no issues previously. This has now been confirmed by yourselves as a Broadband Network Fault and they admitted it was issue at exchange cabinet.
An engineer was sent out to our home who was next to useless. He said that speed was fine and was an issue with our devices, despite having fluctuating speeds on speed test on all devices - ranging from 10 to 70 mbps download, on both ethernet and wifi.
We are having horrendous issues contacting support regarding this. They seem to want to carry out diagnostics every time we call, despite having it confirmed as a Broadband Network Fault - and are unable to switch on the mini hub that was sent, despite there being an open ongoing fault.
Please can you contact urgently to advise where you are in resolving this.
18 REPLIES 18
Message 2 of 19
Re: Broadband Network Fault
Welcome to this user forum. @JamesPlatt_UK
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
It it just during peak times that your speed drops?
JamesPlatt_UK
Message 3 of 19
Hi @Keith_Beddoe
No, this is at any time - we are on Infinity so have had no previous issue with speeds, even at peak times.
Some sites such as BBC load ok but connecting to other sites (BT Interent mail, banking sites, Aviva, Twitch, even google searches) takes a few minutes to connect and times out half the time, on all devices. What is odd is that when dowloading large files we still get full speed.
I had a computer technician look at devices and he could not find any issues with router setting, DNS etc. We even tried a different router and still same issue, both on ethernet and wifi.
I will try calling number as suggested this evening, not at home at moment - at work.
Message 4 of 19
I think that checking for noise on the line would be the first thing to try, as any noise will cause connection issues. Most of what you describe is caused by DNS issues.
Have you tried these steps, its possible the helpdesk has also asked this?
Factory reset the home hub.
http://bt.custhelp.com/app/answers/detail/a_id/11386/%7E/how-do-i-reset-my-bt-hub-to-its-factory-set...
Then turn Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
JamesPlatt_UK
Message 5 of 19
Yes we have tried both multiple times to no avail. I assumed it would be DNS related, have tried different IP addresses e.g. for Google public DNS (8.8.8.8 and 8.8.4.4) and OpenDNS but no joy. Thought it may be a Firmware issue (BTHub6), but issue persists with factory reset and a different router (TP-Link AC1200)
I do not think its anything on our end.
Message 6 of 19
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
JamesPlatt_UK
Message 7 of 19
Many thanks @Keith_Beddoe
Moderator
Moderator
Message 8 of 19
Hi @JamesPlatt_UK,
We'll help you get this resolved. I've sent you a private message with some info on how you can contact us.
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”Kudos”
Moderator
Moderator
Message 9 of 19
@JamesPlatt_UK thanks for sending in your details,  I tried calling there but missed you. I've carried our diagnostics on the line but I'm unable to see any issues with your connection speed. According to the test results the connection speed has consistently synced at over 75Mb for the last few months.
I've also checked to see if there are any known congestion issues affecting your exchange area and these have all came back clear.
My system has emailed the account holder a link to the BT Speed tester and if the instructions can be followed on the email to capture a slow result I can use it to progress the fault with our suppliers
If you could do the quiet line test @Keith_Beddoe has mentioned previously and also post it will help.
If you could also post your router stats will also be a great help as I'm unfortunately unable to see anything untoward when checking the line and broadband connection.
Community ModeratorNeilO
Kudos”Kudos”
JamesPlatt_UK
Message 10 of 19
@NeilO   - Yes Connection speed is showing as 75mbps but loading websites takes forever, see above.
Speed test you sent on email will not run, tried multiple times on different devices - just loads and stays at 'Speed test in progress' screen - for over 45 mins now.
BT Wholesale speed test (from ethernet connected laptop) fluctuates wildly:
Download Speed (Mbps): 49.52
Upload Speed (Mbps) : 12.97
Ping Latency (ms): 19
Download Speed (Mbps): 64.32
Upload Speed (Mbps) : 7.59
Ping Latency (ms): 13
Download Speed (Mbps): 63.60
Upload Speed (Mbps) : 0
Ping Latency (ms): 3416
The 'Further Diagnostics' option will not load when put in phone Number and Post code/Building number - just says test error
Quiet line test:  Slight static between announcements but its a cordless hadset, nothing major.
