griffin9959
Message 1 of 2
Broadband Package Availability/Choice
Help.
Could somebody please help me clarify what BT broadband products I can get/or advise which might be best for me.
My current broadband package is BT Broadband Umlimited.
Over recent years this has given me DL speeds of around 4Mbps to 5Mbps. Over the last six months my connection has been dropping out randomly each day, for between 10 to 15 minutes. However, over the past few days the connection seems to have settled down so, I checked my DL speeds and they are now coming back at 8Mbps, 9Mbps and even +10Mbps.
The poor DL speeds and regular disconnections have had me considering moving over to fibre but, here is where I get confused. Some checkers say I can get fibre and others say no. The ones that do show I goudl get DL speeds between 4Mbps and 9Mbps. This being the case I would think staying with BT Broadband Umlimited would be the obvious choice but, I'm also advised that I can get fibre where the "Avaerage" DL speed is 50Mbps and another saying "Average" DL speed is 67Mbps.
Below is the info from BT BROADBAND AVAILABILITY CHECKER
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
High Low High Low
VDSL Range A (Clean) 10 4.7 1.2 0.8 3.4 Available Available --
VDSL Range B (Impacted) 10 4.7 1.2 0.8 3.2 Available Available --
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand 330 30 -- Available -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 6 -- 4 to 8 Available -- --
WBC ADSL 2+ Annex M Up to 6 Up to 1 4 to 8 Available -- --
ADSL Max Up to 5 -- 3.5 to 7.5 Available -- Yes
WBC Fixed Rate 2 -- -- Available -- --
Fixed Rate 2 -- -- Available -- Yes
Observed Speeds
VDSL
ADSL
Max Observed Downstream Speed (Mbps) -- 7.04
Max Upstream Observed Speed (Mbps) -- 0.45
Observed Date -- 2018-07-21
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available -- --
ADSL Multicast -- -- -- Available -- --
Premise environment
Status
Bridge Tap U
VRI N
NTEFaceplate N
Last Test Date 18-05-2019
What service and best speed can I really get?
Thanks for your input.
1 REPLY 1
imjolly
Message 2 of 2
Re: Broadband Package Availability/Choice
from looking at checker results you are a long way from your street cabinet and and from the speeds shown and you quote I would stay where you are
the 50/67mb quoted are average speeds so some higher and some lower - you are in the very low end at 7/10mb
