Alex5
Newbie
Message 1 of 6
Broadband Problems. (Extremely slow or not working at all)
My broadband is extremely slow. running at 9Mbps upload and 0.4 download. The Broadband will also stop working for large amounts of time during the day and night. The download and upload speeds are below my guarantee and have been for ages now. whenever I've called to report the problem i have been told there is no problem and they wont send out an engineer unless i pay. i am not paying for an engineer as i know there is a problem and an engineer should be sent out to fix this. My package is Super fast fibre 2 unlimited with a BT hub 5 and it should guarantee me upload speed of 17Mpbs minimum. however this 17 is much higher than the 9Mbps i am getting. I want to be able to stream my online games but i cant, i can even play online games such as gta online or call of duty because my upload speeds and download speeds are too low. and half the time the internet isn't working at all.
5 REPLIES 5
Message 2 of 6
Re: Broadband Problems. (Extremely slow or not working at all)
post stats from your hub  troubleshooting then helpdesk
check for line noise  dial 17070 option 2  should be silent and best with corded phone preferably from test socket
enter your phone number and post results  remember delete number  https://www.dslchecker.bt.com/adsl/adslchecker.welcome
Alex5
Newbie
Message 3 of 6
I finally got BT to send an engineer out after 6weeks of asking them. thank you for replying and wanting to help tho. the engineer will be at my place on monday. if what they do doesnt fix it ill get back to you
Moderator
Moderator
Message 4 of 6
Hi @Alex5,
Just a quick post to see how things went with the engineer?
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
Alex5
Newbie
Message 5 of 6
Engineer sorted everything out. Thank you. great service and now the speeds are way above the minimum.
Moderator
Moderator
Message 6 of 6
Hi @Alex5,
That's great, thank you for posting back 👍
PaddyB
Kudos”Kudos”
