Message 11 of 26
Re: Broadband Sudden Dip In Performance
that would not help with your vdsl problem as you have found out
MarkW92
Newbie
Message 12 of 26
I'm stumped as to what to do next... no one from BT that I've spoken to on the phone seems to understand the issue I'm having or given me any solutions to fix it.
Are there any suggestions as to what I should do next?
Message 13 of 26
normally you would report a phone fault to 151 as @pippincp suggested but it appears that @Keith_Beddoe has asked the forum mods to see if they can help which will probably result in engineer visit
just wait now until mods post help here
Message 14 of 26
Line performance issues should be seen by the moderators, as I think they can set up error counters. That tool used to be available, so I assume it still is.
If the line is fine, they it has to be an issue with your own network or devices.
Moderator
Moderator
Message 15 of 26
Hi @MarkW92
Thanks for posting.
Can I ask you to post your router stats for us on the thread so we can take a look at it?
Also can I ask how many devices connect to your hub currently both wired and wirelessly?
Cheers
Stuart
Community ModeratorStuartH
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
MarkW92
Newbie
Message 16 of 26
Hi @StuartH
I've just been in contact with another advisor via live chat who told me my router was 'out of sync' so has sent me a new one. Hopefully this fixes the issue. Thank you for taking the time to get back to me anyway and thanks everyone else for the trouble shooting.
Distinguished Guru
Distinguished Guru
Message 17 of 26
See you back here in a couple of days.
Message 18 of 26
Sorry but would be surprised if that solves your problem and I think you will be back for mod help. I would post the information @StuartH requested
MarkW92
Newbie
Message 19 of 26
@StuartH
Couple of guys said I should still post just in case, despite a new router being sent out.
Currently there are 10 devices connected, 3 via Ethernet (PS4, Imac and BT vision box)Screenshot 2019-02-14 at 19.37.16.png
Distinguished Guru
Distinguished Guru
Message 20 of 26
Not the requested stats.
HH6 Go to: Advanced settings/technical log.
HH5 Troubleshooting/helpdesk.
