Moderator
Moderator
Message 21 of 26
Re: Broadband Sudden Dip In Performance
Hi @MarkW92
The Ethernet devices are they straight into the back of the hub are is there any broadband extenders in use?
Also yes the settings @pippincp mentioned by the method suggested.
Stuart
Community ModeratorStuartH
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
MarkW92
Newbie
Message 22 of 26
@StuartH
The PS4 and Imac are directly linked, the BT Vision box uses ethernet plug sockets to connect it downstairs. I'm sorry I'm not too sure which other bits of information from the router you require, what specific field are you looking for?
Moderator
Moderator
Message 23 of 26
Hi @MarkW92
Advanced stats that may show us some error seconds. Found in Hub Manager, Advanced settings/technical log.
From your original post you mentioned that you streamed and I know you said with ethernet. I know wireless isn't recommended for this but have you tried a test wireless purely to check if issue with ethernet cables etc.
Stuart
Kudos”
Message 24 of 26
@StuartH
None of the recent home hubs show error seconds any more, the powers that be decided that the customer did not need to know.
You should be able to see them from the BT end, unless they have taken that facility away from you?
Moderator
Moderator
Message 25 of 26
hold my hands up to having a moment when advising that one lol.
Trying to rule out internal setup issues as lately have seen issues which sound just like this one and turn out to be extenders/cables.
Stuart
Kudos”
MarkW92
Newbie
Message 26 of 26
@StuartH
I've tried wireless and different ethernet cables as well - the PS4 is also brand new this week as I thought maybe my other one was faulty.
