Message 1 of 7
Broadband VERY slow and going off
My broadband keeps going off at least 6 times today and when it comes back on it is very slow and i cant open more than one window without the other going off saying not enough band width or similar ive tried contacting BT to report a fault but as i cant get a mobile signal here so i cant text them and im not hanging on the phone for 45 minutes thats terrible any ideas anyone ive always had a low signal here but nothing like this
6 REPLIES 6
Message 2 of 7
Re: Broadband VERY slow and going off
The fault isn't going to be fixed unless you report it.
Message 3 of 7
Are you connecting using wireless or ethernet cable? Does the hub light colour change from blue and if so to what colour?
Is your hub connected direct to your master socket or are you using extension socket?
Message 4 of 7
But hanging on for 45 mins is a long time why isnt there an e mail i could send a message to not everyone in the world has a mobile signal to text them
Message 5 of 7
It goes to Magenta pinkish colour and then flashing orange and its a wireless connection and no im not using a extension socket
Message 6 of 7
Which master socket do you have?  If 7 have you checked the front plate is securely connected
If you still connect phone to master socket dial 17070 option 2 should be silent
Message 7 of 7
Yes its option 7
