Balddevil
Message 11 of 59
Re: Broadband boost
Reading that, when the engineer supposedly fixed the fault yesterday he hasn’t done a dlm reset, otherwise  I would be on an open profile.
imjolly
Message 12 of 59
Re: Broadband boost
it may need to be an openreach engineer either that or he forgot
Balddevil
Message 13 of 59
Re: Broadband boost
Sorry for late reply
results with hub in test socket with filter
Balddevil
Message 14 of 59
Re: Broadband boost
And again with hub back out of test socket and where it was before.
Balddevil
Message 15 of 59
Re: Broadband boost
pippincp
Sage
Message 16 of 59
Re: Broadband boost
Ring in and request an engineer as you are below minimum guaranteed speed.
Technonerd
Message 17 of 59
Re: Broadband boost
Yes, this time specifically request a broadband engineer, as it's likely that the last engineer wasn't able to remove the banding due to various reasons (could only be telephony qualified).
NeilO
Moderator
Moderator
Message 18 of 59
Re: Broadband boost
@Balddevil if you need any help with this please use the 'click here to contact the mods' link in my forum profile to send in your details. You can find the link by clicking on my username.
Neil
Balddevil
Message 19 of 59
Re: Broadband boost
I’m still having problems after running various tests with Robbie. Hub is plugged straight into master socket and am getting speeds of 56-58 mb/s ( 66-68 mb/s in test socket)
and connection has been dropping out regularly.
insent a message via contact mods but haven’t received a reply yet.
imjolly
Message 20 of 59
Re: Broadband boost
If you have about 10mb connection speed difference between master and test then there is either a fault with faceplate or more likely with your internal wiring
when you submitted the form following contact mod link you should have received a vol number. Mods take about 2/3 days to respond depending how busy and of course public holidays
