Balddevil
Message 21 of 59
Re: Broadband boost
I contacted them on the evening of the 2nd so hopefully get a response soon.
the faceplate will be 20 years old now so probably the problem. The matersocket is the only one used in the house so I would probably guess that the internal wiring isn’t causing a problem.
thanks for your response @imjolly
imjolly
Message 22 of 59
Re: Broadband boost
If you have and old master socket and old extension sockets then it is quite possible the problem is the internal wiring as the sockets do not have to be in use for the internal wiring to be causing you connection problems
if it is internal wiring problem then if engineer visit you will be charged for callout and fixing connection -£129.99
Balddevil
Message 23 of 59
Re: Broadband boost
Again thanks for the reply and info.
PaddyB
Moderator
Moderator
Message 24 of 59
Re: Broadband boost
Hi @Balddevil,
I can see that @RobbieMac has been dealing with your case. He is out of the office today but back in tomorrow. He will follow up with you then. Please accept my apology for the delay.
PaddyB
Balddevil
Message 25 of 59
Re: Broadband boost
Thanks for that @PaddyB I am on night shift tonight and tomorrow  so between 1pm and 4pm would be good.
DanielS
Moderator
Moderator
Message 26 of 59
Re: Broadband boost
Hi @Balddevil,
@RobbieMac will be in the office then so I'll ask him to contact you between then.
DanielS
Balddevil
Message 27 of 59
Re: Broadband boost
Balddevil
Message 28 of 59
Re: Broadband boost
I’ve plugged hub into test socket again as the connection had become to unstable reducing my download speed daily. It appears my line has been capped again via dlm
Balddevil
Message 29 of 59
Re: Broadband boost
@RobbieMac I’ve just come in off night shift and the connection has been lost again, with the hub in the test socket. Download speed has reduced again to 44mb/s.
would it be possible for you to continue monitoring my connection?
Could there be a problem with my Homehub?
NeilO
Moderator
Moderator
Message 30 of 59
Re: Broadband boost
@Balddevil sorry about that. @RobbieMac is due in this afternoon, I'll let him know that you've posted.
