Message 1 of 12
Broadband connection keeps dropping
Hi,
I recently upgraded to Halo and ever since I have I've had nothing but issues with the connection cutting out and my hub looking like it's at a disco
This happened multiple times and guarenteed to happen everyday, I spoke to live chat previously and they ran tests and flushed my line and they said that would solve the issue but this hasn't fixed anything
Can anyone help me with this or has anyone else had the same issues
Thank you
11 REPLIES 11
Message 2 of 12
Re: Broadband connection keeps dropping
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
Halo is an add-on to your package and should have no affect on your connection
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 12
any help as its over 20,000 characters and cannot paste
Message 4 of 12
Message 5 of 12
Message 6 of 12
23:53:37, 30 May.
:DHCP Confirmation of Request
23:53:36, 30 May.
wl1:A WiFi device <34:79:16:D7:39:5F> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
23:53:29, 30 May.
wl0:Device <34:79:16:D7:39:5F> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
23:53:12, 30 May.
wl0.2:WiFi security settings have been successfully saved
23:53:12, 30 May.
wl0.1:WiFi security settings have been successfully saved
23:53:12, 30 May.
wl1.1:WiFi security settings have been successfully saved
23:53:12, 30 May.
:WAN DHCPv6 Client Prefix : 2a00:23c4:bb83:1700::/56 (valid time = 315360000 / preferred time = 315360000)
23:53:10, 30 May.
ppp1:The WAN DHCPv6 Client Process has successfully been launched on Vlan 36
23:53:10, 30 May.
ppp1:The WAN DHCPv6 Client Process has successfully been terminated on Vlan 36
23:53:08, 30 May.
:HTTP UserBasic login from 192.168.1.87 successfully
23:53:05, 30 May.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been closed
23:53:04, 30 May.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been initiated
23:53:04, 30 May.
ppp1:TR69 receiving InformResponse message
23:53:04, 30 May.
ppp1:TR69 event found : 4 VALUE CHANGE
23:53:03, 30 May.
ppp1:TR69 sending Inform message
23:53:02, 30 May.
23:53:01, 30 May.
23:53:00, 30 May.
BR_LAN:The LAN DHCPv6 Server is active
23:53:00, 30 May.
BR_LAN:LAN Router Advertisement Setting Updated : M_flag = 0, O_flag = 1
23:53:00, 30 May.
BR_LAN: Allocated prefix = fdaa:bbcc:ddee::/64 (valid time = 4293967296 / preferred time = 4293967296)
23:53:00, 30 May.
BR_LAN: Allocated prefix = 2a00:23c4:bb83:1700::/64 (valid time = 2026291200 / preferred time = 2026291200)
23:53:00, 30 May.
BR_LAN: Allocated address = 2a00:23c4:bb83:1700:7a65:59ff:febc:a169 (valid time = 2026291200 / preferred time = 2026291200)
23:53:00, 30 May.
23:53:00, 30 May.
ppp1: Allocated prefix = 2a00:23c4:bb83:1701::/64 (valid time = 2026291200 / preferred time = 2026291200)
23:53:00, 30 May.
ppp1: Allocated prefix = 2a00:23c4:bb83:1700::/56 (valid time = 2026291200 / preferred time = 2026291200)
23:53:00, 30 May.
ppp1: Allocated address = 2a00:23c4:bb83:1701:7a65:59ff:febc:a167 (valid time = 2026291200 / preferred time = 2026291200)
23:53:00, 30 May.
23:53:00, 30 May.
BR_LAN:The LAN DHCPv6 Server is inactive
23:53:00, 30 May.
23:53:00, 30 May.
23:52:59, 30 May.
23:52:59, 30 May.
23:52:59, 30 May.
23:52:59, 30 May.
23:52:59, 30 May.
23:52:59, 30 May.
23:52:59, 30 May.
23:52:59, 30 May.
23:52:59, 30 May.
23:52:59, 30 May.
23:52:59, 30 May.
23:52:59, 30 May.
23:52:59, 30 May.
23:52:59, 30 May.
23:52:59, 30 May.
23:52:59, 30 May.
23:52:59, 30 May.
23:52:59, 30 May.
23:52:59, 30 May.
ppp1:TR69 creating new session with ACS
23:52:59, 30 May.
23:52:59, 30 May.
23:52:59, 30 May.
BR_LAN: Allocated prefix = 2a00:23c4:bb83:1700::/64 (valid time = 240000000 / preferred time = 0)
23:52:58, 30 May.
ppp1: Allocated prefix = 2a00:23c4:bb83:1701::/64 (valid time = 240000000 / preferred time = 0)
23:52:58, 30 May.
23:52:58, 30 May.
23:52:58, 30 May.
23:52:57, 30 May.
23:52:56, 30 May.
ppp1:WAN DHCPv6 Mode : Statefull
23:52:56, 30 May.
23:52:56, 30 May.
23:52:55, 30 May.
23:52:55, 30 May.
ppp1:WAN Router Discovery Setting Updated : M_flag = 1, O_flag = 0
23:52:55, 30 May.
23:52:55, 30 May.
23:52:55, 30 May.
23:52:54, 30 May.
23:52:54, 30 May.
:WAN: SENSING AUTO VDSL
23:52:54, 30 May.
23:52:54, 30 May.
23:52:53, 30 May.
ppp1:New DYN ROUTE is added [81.139.56.100/32 gw 172.16.13.132]
23:52:53, 30 May.
ppp1:New DYN ROUTE is added [81.139.57.100/32 gw 172.16.13.132]
23:52:53, 30 May.
ppp1:PPP: PPP INFO 81.139.57.100,81.139.56.100
23:52:53, 30 May.
23:52:53, 30 May.
23:52:53, 30 May.
23:52:53, 30 May.
23:52:53, 30 May.
ppp1: Allocated prefix = 2a00:23c4:bb83:1700::/56 (valid time = 240000000 / preferred time = 0)
23:52:53, 30 May.
ppp1:PPP: PPP INFO
23:52:52, 30 May.
ppp:PPP: IPCP_NAK
23:52:52, 30 May.
ppp:PPP: CHAP_SUCCESS
23:52:52, 30 May.
ppp:PPP: CHAP_RESPONSE
23:52:52, 30 May.
ppp:PPP: LCP_GOOD_ACK
23:52:52, 30 May.
ppp:PPP: LCP_REQUEST
23:52:52, 30 May.
:PPPoE error: timeout
23:52:48, 30 May.
23:52:42, 30 May.
ptm0.101:VLAN VLAN_DATA connected
23:52:41, 30 May.
:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
23:52:41, 30 May.
:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
23:52:41, 30 May.
dsl:VDSL link Up: Down Rate=65814Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
Message 7 of 12
Waste of time posting the technical log, that is not what was requested.
Advanced settings/thechnical log/information is the page required.
Message 8 of 12
sorry about that
Product name:
BT Hub 6A
Serial number:
+084316+NQ93742392
Firmware version:
SG4B1000E020
Firmware updated:
21-Mar-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
0 Days, 8 Hours 48 Minutes 46 Seconds
Data rate:
19.70 Mbps / 62.28 Mbps
Maximum data rate:
19820 / 62715
Noise margin:
6 dB / 6.1 dB
Line attenuation:
26.4 dB
Signal attenuation:
20.1 dB / 26.4 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
40 MB Uploaded / 3 GB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-R7P8
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-R7P8
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
78:65:59:BC:A1:69
Software variant:
Boot loader:
0.48.8-sec
Message 9 of 12
quiet line test  dial 17070 option 2  should be silent and best with corded phone
Message 10 of 12
i dont have a house phone only the line as we never use the landline
