Distinguished Guru
Distinguished Guru
Message 21 of 40
Re: Broadband disconnects every couple of days
Don't worry @JohnC2 (I'm assuming its him) will keep in touch until your problem is resolved. Your case will remain open until you agree to close it.
Moderator
Moderator
Message 22 of 40
Hi @Mjconnolly  I've just checked the connection again and it is working ok at present. As discussed I will as @pippincp said keep the case open and if the connection drops again we will have to arrange an appointment.  Keep the thread updated if there is any change.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Mjconnolly
Message 23 of 40
Hi all, the connection had been stable for 9 days but this morning I have the flashing purple lights of death again. I will see if I can get a line test to run as that often kicks it into life. Apart from that does anyone have suggestions? @JohnC2 tagging you as you were looking at this for me. Thanks
Mjconnolly
Message 24 of 40
As I suspected, I went on the web page to report a broadband fault, it started checking the connection, and as it did that I got orange then blue lights. Surely this is not a line fault if testing the line fixes the dropped connection every time? Thanks
Message 25 of 40
If you have a high resistance fault on the line, then the line tester will quite often clear the fault, due to the test voltages and temporary line voltage reversal.
Finding where the fault is, usually involves re-terminating all the connection from the fibre cabinet output, to your master socket.
If the fault was on the exchange to cabinet side, it would not affect your broadband.
The fact that the fault was there when you had ADSL, also points to the fault most likely being either on the DP at the top of the pole, or the section from the DP to your master socket, because the cabinet connection would have been re-terminated when you moved over to fibre.
Mjconnolly
Message 26 of 40
Thanks for the info Keith. What’s a DP by the way? All the engineers talk about them but nobody says what they are...!
Distinguished Guru
Distinguished Guru
Message 27 of 40
Distribution Point.
Message 28 of 40
DP=Distribution Point.
In your case, a box at the top of the pole, with lots of connections inside, which can suffer from corrosion.
In apartment blocks or businesses, the DP is sometimes inside, in a cupboard of basement. Sometimes you will see them halfway up the side of a building, usually on older buildings.
Mjconnolly
Message 29 of 40
Ta. Looks like we will need an engineer (again) to investigate this. Presume @JohnC2 will see this on Monday.
Moderator
Moderator
Message 30 of 40
Hi @Mjconnolly I called earlier sorry I could not reach you and to hear your connection has dropped again and stayed down for a long period. I am in the office to noon today can you post back and let me know if you can take a call before noon and I will chat to you then.
Cheers
John
Kudos”
