Message 11 of 18
Re: Broadband drop outs
OK, don't think I've got a filter, will have a look later.
So what am I looking for a drop in the noise on the line (slight hiss).
The dsl will not be conncted if I take the faceplate off ?
Sage
Message 12 of 18
Yes it will if connected to the filter.
If there is a hiss on the line it needs reporting as a line fault no mention of broadband.
Message 13 of 18
You need to leave it connected in the test socket for as long as it takes, to see if you still get the dropout problem.
While its connected like that, do a check to make sure that all extension sockets, if you have any, have no dial tone on them, as they should be routed via that faceplate and connected to the back of the bottom section, as shown here
Extension wiring connection point
If any extension sockets do have dial tone on them, then you have a fault with your internal phone wiring.
Message 14 of 18
Found a filter and fitted as suggested :
Line Status:
DSL Modulation Type:
Annex Type:
  Upstream Downstream
Current Rate(kbps)410722399
Max Rate(kbps)415330319
SNR Margin(dB)6.17.5
Line Attenuation(dB)026.1
Errors(pkts)00
Message 15 of 18
Leave it like that, and see if you still get the packet errors.
Message 16 of 18
24 hours data :
Line Status:
Annex Type:
  Upstream Downstream
Max Rate(kbps)415928192
SNR Margin(dB)6.16.4
Errors(pkts)34547
Message 17 of 18
so connection stable for last 24hrs
Message 18 of 18
What about the errors ?
