OK, don't think I've got a filter, will have a look later.
So what am I looking for a drop in the noise on the line (slight hiss).
The dsl will not be conncted if I take the faceplate off ?
Yes it will if connected to the filter.
If there is a hiss on the line it needs reporting as a line fault no mention of broadband.
You need to leave it connected in the test socket for as long as it takes, to see if you still get the dropout problem.
While its connected like that, do a check to make sure that all extension sockets, if you have any, have no dial tone on them, as they should be routed via that faceplate and connected to the back of the bottom section, as shown here
Extension wiring connection point
If any extension sockets do have dial tone on them, then you have a fault with your internal phone wiring.
Found a filter and fitted as suggested :
Upstream Downstream
Current Rate(kbps) | 4107 | 22399 |
Max Rate(kbps) | 4153 | 30319 |
SNR Margin(dB) | 6.1 | 7.5 |
Line Attenuation(dB) | 0 | 26.1 |
Errors(pkts) | 0 | 0 |
Leave it like that, and see if you still get the packet errors.
24 hours data :
Upstream Downstream
Max Rate(kbps) | 4159 | 28192 |
SNR Margin(dB) | 6.1 | 6.4 |
Errors(pkts) | 34 | 547 |
so connection stable for last 24hrs
What about the errors ?
