Old-Clachan
Message 1 of 12
Broadband dropping out on smart hub
Broadband was not great with Home hub 6 so on advice fron BT bought smart hub. All set up ok and  blue light stays on most of time but even when lit broadband on wired or wireless keeps dropping out. BT say its all ok but its not and can even when on it takes ages to download anything.
11 REPLIES 11
imjolly
Message 2 of 12
Re: Broadband dropping out on smart hub
the hh6 is the smart hub so not sure what is different
post stats from advanced settings then technical log information
try quiet line test  dial 17070 option 2 should be quiet and best with corded phone
enter your phone number and post results  remember delete number  https://www.btwholesale.com/includes/adsl/main.html
are you currently using test socket with a filter to see if that helps your connection?
Old-Clachan
Message 3 of 12
Sorry was hh5 now hh6- mys mistake.
Quiet test all ok and had tried test socket last time I spoke with BT on online chat- this made no difference. Will I try again with test socket and filter?
ADSL checker info pasted below
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date   ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date Left in JumperOther Offerings     Availability Date   Premise environmentStatus
VDSL Range A (Clean)7.94.21.20.83.1Available----
VDSL Range B (Impacted)7.92.71.20.52Available----
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 2--1.5 to 412-Sep-18----
ADSL MaxUp to 1.5--1 to 3.5Available----
WBC Fixed Rate1 ----Available----
VDSL Multicast------Available----
Bridge TapN
VRIN
NTEFaceplateN
Last Test Date23-07-2018
pippincp
Sage
Message 4 of 12
You could've bought a decent router at less money.
Old-Clachan
Message 5 of 12
Hub status info- not sure how to show venet log as this runs on for pages and pages?
Product name:Smart Hub
Serial number:+088047+1812002637
Firmware version:v0.09.06.05093-BT
Firmware updated:Mon Jul 23 16:08:38 2018
Board version:01
DSL uptime:3 days,02 Hours36 Mins15 Secs
Data rate:1.118 Mbps / 8.906 Mbps
Maximum data rate:1.117 Mbps / 9.438 Mbps
Noise margin:6.2 / 6.4
Line attenuation:16.9 / 37.6
Signal attenuation:16.9 / 27.8
Data sent / received:14.5 GB / 10.5 GB
Broadband username:bthomehub@btbroadband.com
BT Wi-fi:Activated
2.4 GHz wireless network name:BTHub6-R56S
2.4 GHz wireless channel:Automatic (Smart Wireless)
5 GHz wireless network name:BTHub6-R56S-5
5 GHz wireless channel:Automatic (Smart Wireless)
Wireless security:WPA2
Wireless mode:Mode 2
Firewall:Default
MAC address:94:6A:B0:8E:A3:AB
Software variant:-
Boot loader: 0.1.6-BT (Fri Sep 9 10:05:09 2016
pippincp
Sage
Message 6 of 12
Did you get the drop outs with the HH5? If not put it back in and return the HH6 for a refund then buy a decent router.
Old-Clachan
Message 7 of 12
Sadly reason I went for HH6 was the drop outs on HH5
imjolly
Message 8 of 12
from your stats the hub has been connected for 3+ days
you are obviously a long way from the exchange and also based on your connection a long way from the street cabinet
Old-Clachan
Message 9 of 12
Fibre runs past our house to exchange 1.2 miles away and then back to us on old copper on poles. 3 months ago all was fine with few drop outs- somethings eems to have changed. Hub has been on for weeks and whilst it says 3 days our signal has gone several times today- whilst blue light stays on
imjolly
Message 10 of 12
As happened on both hubs is it just the wifi?  You have split the bands and changed mode but I would also select manual channels and see if that helps
