Message 1 of 5
Broadband dropping out
For months I have been having problems with broadband dropping out . Engineers have been out 3 times , no problem with my wiring . They say the exchange is at fault . As this went on I changed to fibre hoping it would help . Alas no it still drops out . BT say there are no problems. I would like to know what to do next ?
4 REPLIES 4
Recognised Expert
Message 2 of 5
Re: Broadband dropping out
Are you on FTTP or FTTC?
FTTP is completely independant of any copper wiring which existed before installation and therefore if you're having the same problem with FTTP as you had on ADSL then it's not likely to be a fault with the BT equipment
Moderator
Moderator
Message 3 of 5
Hi @Kilda803,
I'm sorry you're connection has been dropping out. Please can you post your router stats as shown - Top Tips to get help on the forum
This will help to give us an indication of how your connection is performing and where the problem might be.
PaddyB
Moderator
Moderator
Message 4 of 5
Hi @Kilda803,
PaddyB
Message 5 of 5
BT have resolved the proble , I hope
