Ben46
Message 1 of 15
Broadband dropping ut
I have recently been persuaded by BT to upgrade at some cost to Broadband plus to stop my broadband from dropping out.  I have reset the router so many times it no longer recognises my verification code and tells me to try again
Things for going well until last night when the broadband disappeared twice in the space of any hour.  When it came back I tried to check thru the app but got told the connection was too weak.  I telephoned the help line and waited 20 minutes for a reply.  (Good job it is a free phone number)  The guy was very helpful but still no idea why the line keeps going dead.  He said he was going to clean the line and hopefully this would help.
Now I am not sure if I want to pay for the upgrade if it is not going to work
14 REPLIES 14
Message 2 of 15
Re: Broadband dropping ut
have you tried using the test socket with a filter to see if that improves conenction and stability
try quiet line test  dial 17070 option 2  should be silent and best with corded phone
post router stats  if hh6 then advanced settings then technical log information   if hh5 then troubleshooting then helpdesk
enter your phone number and post results  https://www.dslchecker.bt.com/adsl/adslchecker.welcome
when you drop connection does the light on hub stay blue?
you need to stop rebooting the router as that will make matters worse not better
Distinguished Guru
Distinguished Guru
Message 3 of 15
Upgrading to plus will not solve your problem. Cancel the upgrade and save money.
Moderator
Moderator
Message 4 of 15
Hi @Ben46,
Have you had a chance to try the steps suggested by @imjolly? It does sound like it could be a fault on the line or potentially a faulty router.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
Ben46
Message 5 of 15
I would love to try the steps if I could keep my broadband for more than a few hours.  This morning I spoke to people in Dublin, South Shields and Liverpool before `I got back on line.  Twenty minutes later it had gone again.
Watch this space I am obviously paying for nothjing.
Ben46
Message 6 of 15
Couple of quick points - yes the router staysd blue and I have stopped trying to reboot because it no longer recognises the factory setting pass code and just leave me in limbo
Ben46
Message 7 of 15
I have told them this morning that I no longer want the upgrade but because of I am on day 14 and you only have 14 days to cencel I am not convinced I will get my cancellation
Message 8 of 15
if the lights on hub stayed blue that suggest the internet conenction was ok so are you connecting with wifi rather than ethernet?
are you able to post any of the other information I asked for as that will help the forum and mods help you
Ben46
Message 9 of 15
I have never used ethernet ever since I had the system installed.  I cannot run the cables across the hall or up the stairs.
The light sometimes goes green and orange which usually means more trouble.
I am not very technically minded I just like things to work when I switch them on and have the necessary connections to let my husband watch his football and me to chat to our family.
Message 10 of 15
So it is possible that it is actually the wifi connection that is dropping most of the time and not the hub dropping internet connection
really need more information about your connection to enable forum members to help you. If you get engineer callout and problem is actually on your side of the test socket then you will be charged £85
