Ben46
Message 11 of 15
Re: Broadband dropping ut
Problem solved last night it dropped out for over 3 hours so I have decided to pay the cancellation fee and find another supplier who will be a bit more reliable.
Thanks for all your help
Message 12 of 15
hope you have made a good choice but you won't know until the new ISP gets connected  unless virgin the openreach  internet conenction will be same just different router
Ben46
Message 13 of 15
I think I might go back to Talktalk.  I know their connection is slow and lousy but at least I an not paying over £50.00 to use it.  And I do know what to expect
Moderator
Moderator
Message 14 of 15
@Ben46 I'm really sorry to see that you've been having problems with your connection and you're now considering leaving BT.
I've sent you a Private Message with details on how you can get in contact with the mod team if you'd like us to help resolve the issues you're experiencing with your broadband dropping out.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Message 15 of 15
as I said unless you move to virgin the internet connection to your home is the same copper wire from cabinet to your home and difference is in router and who you actually pay  Moving to new ISP as a new customer will give you a good initial reduction in cost     just check your cab is not full otherwise you will not get a fibre conenction but join the waiting list
