Bigbro131
Message 1 of 2
Broadband dropping
We’ve only been with BT a few months, so have the newest hub but ever since we started we’ve encountered problems with it dropping out, however light on the hub remains blue? This gets worse when the whole family is at home but fibre should be able to more than cope with it’s load? I have run the speed check etc and these seem fairly ok. Any suggestions please?
1 REPLY 1
Message 2 of 2
Re: Broadband dropping
if light remains blue then is it the wifi that is dropping and not the actual internet connection
have you split the networks?  http://bt.custhelp.com/app/answers/detail/a_id/56419/~/how-do-i-split-my-bt-hubs-ssid-%28wireless-ne...
did you turn off smart setup  http://bt.custhelp.com/app/answers/detail/a_id/44328/~/what-is-smart-setup-on-the-bt-hub%3F-how-can-...
did you try selecting the channels manually rather than auto?
