Message 11 of 29
Re: Broadband failed after thunderstorm
It sounds like the home hub has been damaged by the storm, do you have a spare home hub or another VDSL router?
Lisah31
Message 12 of 29
No I don't. Thanks for your help though, Keith.
I will just have to wait for the engineer on Wednesday, and hope it doesn't cost me
Message 13 of 29
As you are still in a contract, the home hub will be replaced for free, but there is no guarantee they will have one with them, so you may have to wait for one to be sent by the helpdesk. If there is a lot of storm damage, then there may be a high demand for replacements.
If you cannot wait that long, or would like to keep a spare VDSL router, you can get a basic third party router for £35 or less.
If you are opted into BT Wifi, you can always see if there is a nearby wireless hotspot you can use.
Lisah31
Message 14 of 29
Yes I am still in contract so that's good news about the free router.
If it's definitely the router, it may well be worth me getting a spare so I'll go price one up. Thanks again, Keith
rowelly
Message 15 of 29
Exactly same problem as you, sorry to hijack the thread but thought I'd simply add my details on here seeing as it's an identical problem!
Broadband down since the early hours Saturday, phone line is fine. I have a home hub 3 which I've tried, but no luck with that either. Being half term and having the kids home for a week, the fact an engineer can't come until Friday is pretty annoying to say the least...!
Home Hub 5 shows blue light momentarily (about 15 seconds) then changes to an orange bar, flashing, and stays like that. Socket is MK3, sockets on top of each other; not side by side. Any help would be hugely appreciated if I could get it sorted. Thanks
Lisah31
Message 16 of 29
I'm thinking if its likely the hub, maybe buying a cheap one to make do until the engineer visits might be a way forward for me, especially with the kids off.
Any recommendations on a router? I'm not hugely tech savvy. Thanks
Message 17 of 29
follow the advice already given sound like your hub is faulty
Message 18 of 29
get a hub 5 from a well known auction site
Message 19 of 29
Just get a cheap TP Link TD-W9970, about £30 from Amazon
rowelly
Message 20 of 29
A different router hasn't worked for me unfortunately, tried the home hub 3 (that I've had in a sideboard for a year - i.e. DEFINITELY not storm damaged) and no luck. Hope a new router works for you Lisa!
I've taken the faceplate off the MK3 and tried the test socket and still, no luck. Any suggestions?
