jktownley
Message 11 of 13
Re: Broadband in my area
That much is true.
iniltous
Guru
Message 12 of 13
Wow, joined today, and resurrected a post over 16 months old,  that was marked as having an accepted solution anyway to make what you think is a valid point , IMHO all you have done is make yourself look a little foolish.
If someone posts , on a BT Consumer forum, that it doesn’t matter if you change provider it’s the same network provider , and the comment is made in the same post as a link to the BT wholesale speed checker , then it doesn’t take a genius to realise that it’s referring to providers that use Openreach, there is no need to caveat the comment.
jktownley
Message 13 of 13
I’m just trying to prevent anyone coming across this post, in the future, going away thinking that no other provider can give better speeds – as suggested in the statement: “The infrastructure will be the same whichever provider you use, changing provider won't change your speed.”
If that makes me look a little foolish in your eyes, then so be it.
