Message 1 of 6
Broadband infinity dropouts
Hi, This is my first point of call. I am a new BT customer as from the 19th of this month.
The speeds we am getting are really good and I am very pleased, however, we are experiencing dropouts when the BT hub turns red. It is only usually for a few minutes, but obviously very annoying.
Usually by the time I carry out a speed check it is back up and running.
Any thoughts please?
5 REPLIES 5
Sage
Message 2 of 6
Re: Broadband infinity dropouts
Welcome to the NotSo Smart Hub. Have a look around the forums and you'll see plenty of problems with it.
Message 3 of 6
Oh no!! I could cry! I have just swapped from TalkTalk because their Super Fibre Router was rubbish.
Message 4 of 6
Buy a decent router such as the Billion 8800NL R2. About £50 and your troubles will moat likely vanish.
Message 5 of 6
Is that really the only answer? I know people locally who have/had BT and not experienced this problem, that's why I changed to them 😕
Message 6 of 6
It's not the only answer but you can go round the merry go round of engineer visits, hub replacements in the hope it'll resolve the problem if you wish.
