fireblazer2k6
Message 1 of 6
Broadband keeps dropping out
Hi,
My broadband keeps going slow and dropping out.
BT say I should get a 37Mbps connection.
I have tested for a full day without anyother devices connect bar my ps4 connected via network cable straight into the router. I launch one of the streaming services I pay for in this case Netflix. I have launched one of the movies that can play in 1080p and then check a little option to see what quaity the film is playing and shows as 480p. Now Netflix site says that it only takes about 5Mbps to get a 1080p film to stream. I had no issues with the service before christmas and I have not changed anything since certainly nothing that would affect a network cable connection. BT agents tell me that im wrong and there is nothing wrong with my service but its clearly been throttled in some way. Anyway after watching 15mins of a movie in 480p netflix buffers and says a message about the bandwidth not being good enough and this is where I have to reset my router.
Next test when the issue happens I try and access google from my iPhone 6 it says no connection. I restart the router and it fixes the issue. However I never get full 1080p streaming.
BT told me again I am wrong and that there is no issue.
Next test I tried Amazon Prime same thing happens it buffers after streaming poor quality then says not enough bandwidth then i have to restart the router to fix the issue. Just to add when i just restart the app on the ps4 it launches the streaming service and just gives the error.
I have no more than 4 items that are connected to the network and BT state this is to many and that this is the issue when it clealy is not.
Also I have been told that a 2.3Mbps over the wifi from the home hub 5 is acceptable and normal. When I was with talk talk i got full 30Mbps or so the PS4 picked up anyway.
BT have told me to do their speed check several times and it comes up as 37Mbps I have used several trusted speed tests and they say my average is between 11Mbps - 12Mbps
I have litterally had enough of BT saying I am wrong and I have even raised a complaint. I got told also I am wrong and that they will call me in a couple of days to close the complaint.
Also why can the BT agents not understand that paying almost £50 for their poor service is not acceptable. (This does include line retail)
5 REPLIES 5
Message 2 of 6
Re: Broadband keeps dropping out
if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post 1-12
can you run btspeedtester and when first test completes then run diagnostic test and post results  must be done with wired connection  btspeedtester
 are you using the test socket with a new filter or can you use test socket
can you enter your phone number and post results  remember to delete number wholesale FTTC check
try quiet line test   dial 17070 option 2  should be quiet and best with corded phone
fireblazer2k6
Message 3 of 6
Hi imjolly
I appreciate your time to help this is great the results are as follows.
1. Product Name: HomeHub5
2. Serial number: +076284+1519008566
3. Firmware version: v0.07.05.0A13-BT (Type B) Last updated 10/12/2015
4. Board version: 01
5. VDSL uptime: 0 days, 00:31:11
6. Data Rate: 9995 / 39998
7. Maximum Data Rate: 13100 / 51222
8. Noise Margin: 6.6 / 9.7
9. Line Attenuation: 23.0 / 18.7
10. Signal Attenuation: 0.0 / 0.0
11. Data sent/received: 7.4 MB / 350.9 MB
12. Broadband username: bthomehub@btbroadband.com
Exchange BLYTH is served by Cabinet 27
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
  HighLowHighLow
FTTC Range A (Clean)6750.62014.5--Available
FTTC Range B (Impacted)49.625.916.56.7--Available
WBC ADSL 2+Up to 7--4.5 to 11.5Available
WBC ADSL 2+ Annex MUp to 7Up to 14.5 to 11.5Available
ADSL MaxUp to 5.5--4 to 8Available
WBC Fixed Rate2----Available
Other Offerings
Fibre Multicast------Available
Copper Multicast------
Available
I have done the queit line with BT wireless phones I dont have a wired one but it was quiet.
Tags (3)
Message 4 of 6
As you can see from the stats you have posted you have max connection speed 40/10mb for infinity 1 and your download speed are good and consistent with your connection speed and profile
Looks as you would expect
ISPS don't guarantee speed over WiFi as there are to many variables with affect WiFi speed
fireblazer2k6
Message 5 of 6
Why is mentioning Wireless a get out clause this does not explain why I have such issues with a wired connection. I tried to watch a film again last night on Netflix I had to restart the router 4 times within 30mins. If I dont restart the router and try and connect my laptop by a cable i cannot access the internet. All these results show is when its on its working. I cannot access these sites to do test when I have no connection. Also BT not able to gaurantee wireless speed you might as well say BT is **bleep** and their hardware is as well. The BT HH 5 should be able to provide a good stable connection for me. So let say we forget the issue with wifi for the time and tell me why my cable connection is so **bleep**. Before christmas I had the same setup and i had no issues and I have changed absolutly nothing. I have tried to complete a throttling test and it wont complete i think it starts at 500 seconds to go and gets to 420 seconds and hangs. I think BT are telling me porky pies.
At least the one thing I do appreciate you did more tests then any other BT agent has with me and I apprciate that.
Below are photos from Netflix and Amazon this is while i am connect via a wired connection. Netflix should show 1080 instead of 480 and well Amazon is pretty much telling me the issue and the PS4 has no way of throttling the broad band service and when I only have the ps4 connected to the network and nothing else i get these issues.
Weeks ago I phoned BT and the lady said i did have an issue with the broadband and secondline would call me to fix it. No phone call and it was not fixed. Everytime i contact BT now they dont know what im talking about like the call never happened.
Message 6 of 6
as it says at top of forum this is a customer help customer forum and everyone here is a customer just like you and I and only BT employees are the forum mods
