Predator215
Message 1 of 11
Broadband no connection
Hello to all is anyone else having the same problem in the ramsgate area that happend on the 10th of March. No internet connection but full signal which I believe is down to the junction box or cabinet.
10 REPLIES 10
Message 2 of 11
Re: Broadband no connection
You will get a full wireless signal even although the Internet is down. The wireless signal is broadcast from your Homehub not the Internet.
Use this link to check to see if there are any reported problems in your area.
https://my.bt.com/consumerFaultTracking/public/faults/tracking.do?pageId=31
Message 3 of 11
Are you sure that its not just you affected?
What colour are the lights on the BT Home Hub?
Sage
Sage
Message 4 of 11
There is no reprted cabinet issue in Ramsgate area.
Message 5 of 11
@Predator215
Do you have dial tone on your phone?
Predator215
Message 6 of 11
Yes I can dial and receive calls.
Predator215
Message 7 of 11
Flashing pink it’s was the same the other week engineer came round and said that my end and lines were all good and it was a problem with the cabinet and 50 others were effectied.
Predator215
Message 8 of 11
Done that but thanks
Message 9 of 11
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Moderator
Moderator
Message 10 of 11
Hi @Predator215,
I am sorry to read about this ongoing fault. I've sent you a private message with details on how you can get in touch with us.
Also, thanks for flagging this to me @Keith_Beddoe
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”Kudos”
