jwilliamperks
Message 1 of 27
Broadband problem
Here we go again,
Friday morning I got up tried to  go online. Nothing happened. There's a blue light on HUB but no browser will connect. Getting timeout messages and server stopped responding messages. Speed test app won't run and says 'latency error'.
We've got a phone line and can make calls.
If I slave any of my tec to a mobile phone wireless hotspot then everything works fine so I don't think its a problem with my Ipad, Ipod or netbook.
Rang BT and they reset the line. This has made no difference.
Reset the HUB - hard reset and reboot and the blue light is on but still getting the same problem.
Any ideas?
There is a fault logged.
Also used a wired and wireless connnection
26 REPLIES 26
Boudges
Message 2 of 27
Re: Broadband problem
What bt hub are you using?
If you liked a post, please click on the 'Ratings star' on the left hand side of the post.
Message 3 of 27
jwilliamperks
Message 4 of 27
Hub 5 I think
jwilliamperks
Message 5 of 27
Nothing listed for my area
Message 6 of 27
Cannot think of anything else. It may be a new fault that does not show on the status page yet.
See if your exchange code shows up on this page https://status.zen.co.uk/broadband/
This tends to give more info that the BT one.
Boudges
Message 7 of 27
If you have access to another hub then it might be worth swapping them to see if you have a a faulty hub. Only try this if there are no faults in your area
jwilliamperks
Message 8 of 27
There is planned maintenance listed for my dialing code area for 2/12!
Message 9 of 27
Perhaps it a faulty card, and that is when they intend to replace it?
Often these are done as a planned work, if its going to affect a lot of customers.
Does it mention that its a fibre cabinet issue?
jenger72
Message 10 of 27
I'm afraid that this won't help you, but I have a similar problem - my Home Hub 6 seems to be seriously flakey: it'll have blue lights, everything is apparently connected fine etc. and yet several times a day, I'll lose connectivity for a variable amount of time. Rebooting the hub sometimes "fixes" it, sometimes doesn't.
I also use 4G on my mobile to get myself out of a tight spot, and like you, everything works perfectly when I do so.
Based on my experience, the HomeHub6 is much worse for this than the HomeHub5 - and that wasn't great! 😞
