jonmanley
Message 1 of 10
Broadband speed continually being erroded
My fibre to the cabinet service was once excellent @60mbps at the end of 2017.
Over 2018 and 19 it has slowly dropped away and is now down to 38.
Please advise/help.
Jon
9 REPLIES 9
Keith_Beddoe
Message 2 of 10
Re: Broadband speed continually being erroded
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Can you please display the connection information.
If you are using the BT Smart hub you can get your connection stats by, Opening a new web browser on your connected device and type 192.168.1.254 or bthomehub.home into the address bar. This will open the Hub Manager.  Click Advanced Settings’ and then ‘Technical log’
imjolly
Message 3 of 10
Post stats from hub. If hh6 then advanced settings then technical log information. If hh5 then troubleshooting then helpdesk
enter your phone number and post results remember delete number   https://www.btwholesale.com/includes/adsl/main.html
jonmanley
Message 4 of 10
Thanks for the quick reply.
Seems quiet to me.
HH4
Here are the stats if it is of interest:
imjolly
Message 5 of 10
If you are using a hh4 then you must have a separate modem and unless unlocked you cannot access the stats which are held by modem not the hub
jonmanley
Message 6 of 10
I do have a seperate modem and it is not unlocked.
jonmanley
Message 7 of 10
So - without the stats from the modem what is the next thing I can do/try?
imjolly
Message 8 of 10
without stats it is difficult to see what is happening     connection speed appears to be about 44mb not the 38mb you mention which presumably is a download speed
you cannot tell what the connection time is and if the modem is dropping connection - often?
have you tried the test socket with a filter to see if that helps
jonmanley
Message 9 of 10
I am not aware of the connection being anything but solid, just slower than it was.
The 38 is the download speed according to Speedtest.
The connection is direct to the master socket, but I could try thr test socket and filter.
topleya
Message 10 of 10
Hey,
I'm experience the exact same issue. I was once getting around 70mbps down, now I get no more than 55mbps (almost like its locked at 55)
I've been trying to fix this issue for a while, with no success. My hardware and settings have remained the same
https://community.bt.com/t5/BT-Fibre-broadband/50Mbps-on-Fibre-2-Since-Late-2017/td-p/1928785
