Message 11 of 17
Re: Broadband speed down to 14mbps
@keithp Whilst appreciating you are connected via WiFi, have you tried, if possible, running an ethernet cable directly to your PC or laptop? Then you should see if there’s a speed issue or not. If it’s solely dropped speeds on WiFi, then that is where the problem would I suspect, lay.
Message 12 of 17
Yes try that suggestion. We have bought faster internet  (eg just now mine on my PC was 3 GB - so I think that is about 3000 mbps and very fast. I have been testing all over the house. We get fastest speeds with ethernet cable - that might be a simple solution. It is not very hard to run it to the place you use your PC.
Message 13 of 17
Ok - I can't connect via  a cable at the moment as it means moving the desktop/ monitor and I dont have a cable anyhow. But I have double checked everything again - it seems the new W11 laptop continues to show speeds of 74 and only drops if the desktop is turned on, then it shows 35. Both the BT app and the  BT site show a good connection for wifi. If I turn the desktop on, it shows 74 but it is after  some use that it drops - a few mins ago I checked it and it had gone to to 13. If I restart I get the 74 again. I have checked the LAN drivers are up to date. Also the inbuilt HP checker shows a good connection.
So is it something to do with the PC, in which case how do I reinstall all the drivers for the wifi or is it something else?  I understand you can ask an engineer to come and check your network - is it worth doing that?
Message 14 of 17
Even if you had BT Halo , and requested the included  BT visit to check your setup , it doesn’t include changing any settings  in your own equipment, it’s purpose is simply making sure the BT kit is optimised for your home , if you don’t have Halo then BT support runs to remote diagnostics (of the BT kit not your own kit )
If your own equipment is the problem, or the Windows operating system you probably need to join and ask questions on forums that specialise in your equipment manufacturer or the operating system provider, and as far as getting an Openreach engineer visit on the pretext of a ‘fault’ , again if the speed it fine to the router (that’s why you were asked to provide the router connection statistics) then that’s all they get involved in , with the myriad of equipment that can be connected to the ‘internet’ your ISP and Openreach are only expected to be familiar with the things they supply, not the huge number of devices they didn’t supply that can be connected to the router .
Message 15 of 17
Hello All
I am still having issues so I have another question please.
The set up I have is a desktop and a laptop, the hub is in the lounge, the desktop in a spare bedroom on the same floor and around 40 feet away. There is a hall with two doors, always open between the hub and the desktop. Having tested both the desktop and laptop, I am sure the issue is the desktop and ts wifi adaptor, so I am looking to get a replacement USB adaptor. My question - the download speed to the hub is 74, now from the hub to the two computers does the speed stay at 74 or around that mark for each or is it split between the two? When I put the laptop next to the desktop and had both on playing the same you tub video as a test, the laptop speed was 60, the desktop was 5.
So is the speed split or a constant to any device?
Message 16 of 17
I’m not sure what you are actually asking , but if your ‘speed’ to the hub is 74Mb , then clearly neither device can exceed that and it overly simplistic to say it’s 37Mb each , depending on what ‘demand’ is required by each device, which will change millisecond to millisecond, each device (assuming the appropriate connection can provide the bandwidth , Ethernet or WiFi ) can to all intents use all the available bandwidth upto 74Mb , the only time realistically you would expect to see approximately 37Mb on each device is if you ran simultaneously a speed test on each one .
The chances are 74Mb will more than exceed what two devices demand without any noticeable delay , for example a 4K HD stream (a bandwidth intensive demand) is around 25Mb , so even if both devices were watching a 4K stream , there is still a 24Mb bandwidth headroom for other stuff , chances are nothing you will be doing will be anywhere near that .
The allocation of bandwidth is dynamic, depending on what each device requires, and for all but the busiest households with multiple TV’s watching HD/4K streams , phones, tablets , laptops etc all online at the same time , chances are you won’t exceed the bandwidth available.
Message 17 of 17
Ok thanks. All I need now is a working wifi adaptor.
Anyone tried this at all?
 TP-Link Archer TX20U Plus AX1800 WiFi 6 Wireless USB Adapter
Keith
