djphoto7896
Message 11 of 23
Re: Broadband speed dropping
Bt sent an engineer out turns out the wiring to the pole outside was knackered .speed has increased a bit now
Techwizz
Expert
Message 12 of 23
Great news!
djphoto7896
Message 13 of 23
Well the Plot thickens it's now back down to 29mb download how do I get back on standard broadband which was more reliable than the ultrafast
imjolly
Message 14 of 23
can you repost stats from hub please  are you using the master socket or preferably the test socket?
djphoto7896
Message 15 of 23
Product name,HomeHub6
Serial number,+088047+1709002634
Fireware version,v0.09.06.05093-BT (Wed May 9 17:52:38 2018)
Board version,01
DSL uptime,0 days 5 Hours 48 Mins 8 Secs
Data rate,4Mbps/32Mbps
Maximum Data rate,4 Mbps/41 Mbps
Noise margin,59/98
Line attenuation,323/217
Signal attenuation,313/200
Broadband username,bthomehub@btbroadband.com
BT Wi-Fi,Activated
2.4 GHz wireless network name,BTHub6-S65P
2.4 GHz wireless channel,Automatic (Smart Wireless)
5 GHz wireless network name,BTHub6-S65P-5
5 GHz wireless channel,Automatic (Smart Wireless)
WirelessSecurity,WPA
Band steering,No
Wireless security,Mode 1
Firewall,Default
MAC address,E0:51:63:AE:1C:EB
Software variant,-
Boot loader, 0.1.6-BT (Fri Sep 9 10:05:09 2016)
imjolly
Message 16 of 23
Connection time only 5hrs was that a manual reset?
Was stats from connection to master or test socket?
djphoto7896
Message 17 of 23
manual reset to see if that helped.Thing is my line speed from the cabinet tothe hub is only 29mb
Techwizz
Expert
Message 18 of 23
It's 32 Mb, but there's obviously still a problem, so you need to get back onto CS and book another engineer appointment.
imjolly
Message 19 of 23
constantly rebooting your router will actually make your connection worse not better - stable is best
djphoto7896
Message 20 of 23
Sending meanotherengineer
