Megabine
Message 1 of 8
Broadband speed has been slowing down as of later
I remember last year when my speed were around 28Mbps Download and 5 Mbps Upload.
Now all I get is around 23Mbps Download and barely above 3 Mbps Upload.
It doesn't seem like a lot, I love with 2 more people, each one of them has their own devices and one of them regularly watches netflix.
I've gone to the DSLchecker website and I should be getting 27.44Mbps Download and 4.64Mbps Upload.
I'm not sure if it's a fault with the cabinet, the cables on the street or just my router, I have 2 routers, I've switched between both of them and speed hasn't changed.
Is there anything I can do to fix this issue or will BT only do anything unless the value goes under the "Minimum speed"?
7 REPLIES 7
Moderator
Moderator
Message 2 of 8
Re: Broadband speed has been slowing down as of later
Hi @Megabine welcome to the community, can you post your router stats and we'll be happy to take a look?
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Message 3 of 8
the dslchecker shows connection speeds not download speed
as well as posting stats can you enter phone number and post checker results  https://www.dslchecker.bt.com/adsl/adslchecker.welcome
Megabine
Message 4 of 8
Router:
Product name:
BT Hub 6A
Serial number:
+084319+NQ71367049
Firmware version:
SG4B1000E016
Firmware updated:
02-Jul-2019
Board version:
1.0
Gui version:
1.105.0
DSL uptime:
0 Days, 0 Hours 9 Minutes 0 Seconds
Data rate:
4.07 Mbps / 25.24 Mbps
Maximum data rate:
4070 / 25760
Noise margin:
6.2 dB / 3.4 dB
Line attenuation:
27.8 dB
Signal attenuation:
0 dB / 27.8 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
1 MB Uploaded / 5 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-2P35
2.4 GHz wireless channel:
Channel 1
5 GHz wireless network name:
BTHub6-2P35-5
5 GHz wireless channel:
Channel 44
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
A0:8E:78:20:CC:27
Software variant:
Boot loader:
7.33.1
Also did an Ethernet speed test and im getting 21.5Mbps download and just under 4Mbps upload.
Moderator
Moderator
Message 5 of 8
Hi, @Megabine many thanks for replying. The sync speed to your Hub is showing it's the download at 25.2Mbps and upload at 4Mbps and there doesn't appear to be anything out of the ordinary that would be causing issues with the speed.
If you could post the results from that check that @imjolly asked for it will help us determine what sort of speed range to expect from your line.
The connection time was only 9mins did you reset the Hub?
Kudos”Kudos”
Megabine
Message 6 of 8
VDSL Range A (Clean)3322.35.93.719.2AvailableAvailable--
VDSL Range B (Impacted)32.3195.93.214.8AvailableAvailable--
FTTP on Demand33030--Available----
And this is my ethernet speedtest without having anyone else use the internet
https://www.speedtest.net/result/8459311836.png
Message 7 of 8
from looking at the information you have posted you are within the expected range of connection speed both down and up and with noise margin down currently at 3db would suggest G.INP is active
your download speed, which is not guaranteed, is at 20mb which after allowing for overheads is consistent with a 25mb connection speed
connection looks as expected
Moderator
Moderator
Message 8 of 8
Hi @Megabine thanks for doing that, I have to agree with @imjolly I'm afraid there doesn't appear to be any scope for improvement, sorry.
Kudos”Kudos”
