Sage
Message 21 of 23
Re: Broadband speed not as promised
BT Wholesale test doesn't bother about what router you use, it simply measures the parameters of your connection.
Message 22 of 23
OK thanks, I'll try to get the stats again.
Message 23 of 23
I have tried to get the BT Wholesale diagnostic test results and it reports an error, tried several times and failed.
My download test results for BT Wholesale is,
Download speed (Mbps): 19.39
Upload speed  (Mbps): 3.12
Ping Latency (Ms): 33.25
and the stats from the router are,
ADSL LinkDownstreamUpstream
Connection Speed20669 kbps3575 kbps
Line AttenuationD0( 24.0) D1( 69.0) D2(N/A) dBU0( 6.4) U1( 56.8) U2( 63.3) U3(N/A) U4(N/A) dB
Noise MarginD0( 5.7) D1( 5.7) D2(N/A) dBU0( 7.3) U1( 6.1) U2(N/A) U3(N/A) U4(N/A) dB
