Fulbourn
Message 1 of 4
Broadband speed- signed up for 52Mbps
Having changed providers to sign up to the 52Mbps package from BT I actually receive a maximum of 39 Mbps.  Should I consider this acceptable as that speed is available more cheaply?
3 REPLIES 3
Message 2 of 4
Re: Broadband speed- signed up for 52Mbps
post the stats from your hub  if hh6 then advanced settings then technical log information
enter your phone number and post results remember delete number  http://dslchecker.bt.com/adsl/adslchecker.welcome
Fulbourn
Message 3 of 4
BT BROADBAND AVAILABILITY CHECKER
Telephone Number on Exchange FULBOURN is served by Cabinet 2
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date   ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date Left in JumperOther Offerings     Availability Date   Premise environmentStatus
VDSL Range A (Clean)8062.5201955AvailableAvailable--
VDSL Range B (Impacted)7648.82013.339.8AvailableAvailable--
G.fast Range A (Clean)161.4139.221.78.1113.5AmberAmber--
G.fast Range B (Impacted)121.778.913.66.471.4AmberAmber--
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 17--10 to 19.5Available----
WBC ADSL 2+ Annex MUp to 17Up to 1.510 to 19.5Available----
ADSL MaxUp to 8--7 to 8Available----
WBC Fixed Rate2 ----Available----
VDSL Multicast------Available----
ADSL Multicast------Available----
G.fast Multicast------Available----
Bridge TapN
VRIN
NTEFaceplateN
Last Test Date08-05-2018
Message 4 of 4
are you able to post stats from your hub?
