jaypeegolf
Message 11 of 39
Re: Broadband speed very different depending on test site?
So there's no 'speed test' to measure speed to my hub like BT quote?
Message 12 of 39
The hub stats tell you that.
matekaneve
Message 13 of 39
Have you tried to use the test socket? Connect your hub to that and see if that makes any difference.
matekaneve
Message 14 of 39
Just to prove the speedtest.net servers are overloaded and will give you different results!
First is Middlesbrough server with 44Mbps, the second is Newcastle server with 59 Mbps and the last is the result from speedof.me test site with 63Mbps. Use the test socket and check the speed on different servers with wireless and wired connection as well. If you still have issues I think a moderator will probably have a look at this for you.
jaypeegolf
Message 15 of 39
Thanks for your suggestions.
We don't have a 'wired' device at home so any tests I run will be over Wifi! I'll check my hub stats for more info.
ZooBurner
Message 16 of 39
This has always been the case, though it seems that the different sites give consistently differing results.
I'm used to what is normal for that site and don't concern myself too much with the discrepancies between them
Moderator
Moderator
Message 17 of 39
Hi guys,
Thanks all for posting. There's some usefull comments on this thread. We would always recommend using the wholesale speed tester on a wired connection but you'll also see your connection speed in your hub stats (thanks @licquorice @pippincp for pointing that out). Wireless will alwys show a descrepency in the speed but I take your point @matekaneve . I hope you've got the advice you were looking for @jaypeegolf .
Cheers
David
jaypeegolf
Message 18 of 39
Can someone point me where I’ll find my home hub stats please? I’ve looked everywhere but nothing obvious
jaypeegolf
Message 19 of 39
Can anyone tell me where I’ll find my hub stats? Looked everywhere but nothing obvious
Sage
Sage
Message 20 of 39
HH6 Advanced settings/technical log/information.
HH5 Troubleshooting/helpdesk.
