Message 1 of 17
Broadband speed
Hello, I've been having issues with my broadband speed for the past month. My broadband package is currently 'Fibre 1' that has 67-73Mb download speed range with guarantee 62Mb minimum. I've been doing daily speed test for the past month and I've always been getting 34-38Mb only. The upload speed and ping are completely fine but the download speed is having big issues. I haven't seen it reach 60Mb+ in over a month now. I'm also currently using an ethernet cable connected directly to my PC.
I've restarted my BT Smart Hub many times, but the problem doesn't get solved doing that.
Is there anything I should do to fix this problem?
16 REPLIES 16
Message 2 of 17
Re: Broadband speed
Hi @DatChu sorry that your speed has dropped. Have you checked the telephone line for any noise interference? Dial 17070 on a corded phone preferably and the line should be quiet, if using a cordless phone you may hear a slight hum.
Also can you post your hub stats? As you are using the BT Smart hub you can get your connection stats by, Opening a new web browser on your connected device and type 192.168.1.254 or bthomehub.home into the address bar. This will open the Hub Manager.  Click ‘Advanced Settings’ and then ‘Technical log’
cheers
John
Message 3 of 17
Re: Broadband speed
in addition to info requested by @JohnC2  can you enter your phone number and post results  remember delete number
Message 4 of 17
Re: Broadband speed
Product name:
BT Hub 6A
Serial number:
+084316+NQ75140337
Firmware version:
SG4B1000E020
Firmware updated:
14-Mar-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
0 Days, 1 Hours 52 Minutes 45 Seconds
Data rate:
14.17 Mbps / 38.88 Mbps
Maximum data rate:
14174 / 40136
Noise margin:
6.1 dB / 6.3 dB
Line attenuation:
20.7 dB
Signal attenuation:
17.7 dB / 20.7 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
94 MB Uploaded / 737 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-R9GM
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-R9GM
5 GHz wireless channel:
Smart (Channel 44)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
3C:17:10:77:55:53
Software variant:
Boot loader:
9.2.0
Message 5 of 17
Re: Broadband speed
Hi imjolly,
Just for confirmation, which phone number do you need in that link? Home or mobile?
Message 6 of 17
Re: Broadband speed
Home
Message 7 of 17
Re: Broadband speed
Message 8 of 17
Re: Broadband speed
Quiet line test? 17070 option 2.
Message 9 of 17
Re: Broadband speed
are you connected to the master socket or better still the test socket with a filter to see if that improves your conenction speed  if you connect to test socket then repost your hub stats
Message 10 of 17
Re: Broadband speed
Sorry for the delayed reply, imjolly.
This is what it's connected to:103604232_3967334476642116_4314427689959633562_n.jpg
