AmyV
Message 11 of 14
Re: Broadband speeds lower than guaranteed!
It was with both.
I just confirmed that I'd performed the speed tests/BT wholesale etc. through an ethernet and wireless connection for best results.
After the engineer has now just reset the router and performed his tests, I am receiving 67Mbps download through ethernet/power line, but WiFi still remains between 30-40Mbps.
Because of this, the engineer said it's probably a faulty router, resulting in slow Wifi throughput.
The two WiFi bands are already split. I did this before I even had the issue.
Message 12 of 14
Have you tried changing channel?
AmyV
Message 13 of 14
I've used inSSIDer so that both bands are on the best channels
AmyV
Message 14 of 14
BT are sending me a brand new router, should be here by Friday.
I'll give that a try and see what happens.
Hopefully it's just a fault with the router, the engineer said he wouldn't be surprised if it was!
