J_graham
Message 1 of 7
Broadband speeds
My BT contract had now ended and I am wondering what package to sign up for next.     My current package is Superfast fibre unlimited but I am only getting download speeds of 11mbps, which doesn’t seem “superfast” to me.  Should I be able to get better speeds on this package or should I be looking for a different package?
6 REPLIES 6
Message 2 of 7
Re: Broadband speeds
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
This will show what speeds your line is estimated to get and will allow for a more informed answer to be given.
J_graham
Message 3 of 7
Message 4 of 7
Can you post hub stats. If hh6 then advanced settings then technical log information
if hh5 then troubleshooting then helpdesk
from dslchecker you cannot get speeds faster than the new BT Essential package   You can phone 0800800030 options team and see what they offer fir essential and superfast 1 and then decide
J_graham
Message 5 of 7
J_graham
Message 6 of 7
Have you been able to learn any more from the hub stats I posted?
Message 7 of 7
your connection time was only 14hrs was that due to router dropping connection or manual reset?  your noise margin is high as normal about 6db so are you having connection problems?  check line noise  dial 17070 option 2  should be silent and best with corded phone from test socket
have you tried using the test socket with a filter to see if that improves connection/attainable speed?
