Voyager
Message 1 of 16
Broadband v Landline line
I have BT Homehub 2 and BT BT8500 Advanced Call Blocker telephone.   Receiving or making a telephone call causes my Homehub to reset itself each time.  Has anyone ant idea why this is and can I prevent this happening ?
Rregards and thanks
Alan
15 REPLIES 15
Keith_Beddoe
Message 2 of 16
Re: Broadband v Landline line
I assume its ADSL broadband that you are using?
Voyager
Message 3 of 16
I think ADSL fibre
Keith_Beddoe
Message 4 of 16
@Voyager wrote:
I think ADSL fibre
No such thing,
Is it just a home hub 2 which is connected directly into your phone socket, without a white Openreach modem?
Your other posts indicate ADSL.
Voyager
Message 5 of 16
Just a home hub 2 connected directly into the phone socket.
Keith_Beddoe
Message 6 of 16
The usual cause of this problem is a high resistance connection or noise on the phone line.
There is another issue with the old home hub 2, as it has obsolete internal phone circuitry which used to be needed for the obsolete hub phones.
This can develop a fault which causes the same symptons as you describe. I am surprised that there are still people using the home hub 2.
The first thing to do is to eliminate any possibe  problems with your internal wiring.
You need to check at the test socket first.
Connect things up as shown above, and see if you still get the disconnections when the phone rings.
Voyager
Message 7 of 16
My hub is the Smart Hub 2, which is the latest wi fi in all rooms hub.  Does this make a difference to information in your reply ?
Keith_Beddoe
Message 8 of 16
You originally said the home hub 2, which I assumed you still had from your posts a few years ago.
https://community.bt.com/t5/Home-setup-Wi-Fi-network/BT-Hub-Phone-2-1/m-p/550755#M25146
The smart hub 2 is totally different so I assume you must now be on superfast broadband and not ADSL, is that correct?
Voyager
Message 9 of 16
After checking I find that I am on Superfast Broadband, sorry for the confusion.
Keith_Beddoe
Message 10 of 16
This thread is now in the correct place.
The process for checking the line using the test socket, is still the same.
