Jason-steptoe
Message 1 of 9
Broadband
Hi, I’ve had some electrical work carried out in my house over the last few days, they have been turning the electric on and off many times but now my internet speed has dropped from 62meg to 10. How long does it take to reset or do but have to reset my line? There is no problem with the actual phone line.
many thanks
jason
8 REPLIES 8
Keith_Beddoe
Message 2 of 9
Re: Broadband
Welcome to this user forum.
It should eventually recover, provided you do not disconnect or restart the home hub. It may take a couple of weeks.
imjolly
Message 3 of 9
Re: Broadband
as @Keith_Beddoe says just maintaina stable connection and connection should recover but I think nearer couple of months rather than weeks to get speed fully back
Techwizz
Message 4 of 9
Re: Broadband
@imjolly, agreed.
That's some very harsh banding. It's always a good idea to turn off the Hub whilst any electrical work like that is carried out. It may be better to try and get a DLM reset, but that could be difficult.
pippincp
Message 5 of 9
Re: Broadband
Provided you keep a stable connection you should see your speed rising again (allbeit slowly) within 2 weeks.
I would suggest you post your hub connection stats sometime today so and  again in 2 weeks for comparison if need be.
HH6 Advanced settings/technical log.
HH5 Troubleshooting/helpdesk.
As @imjolly says it could be month before full speed is returned but in situations like yours it is normally quicker.
Come back in 2 weeks if you haven't seen an improvement.
Jason-steptoe
Message 6 of 9
Re: Broadband
Thanks,
I have been using a ASU’s dsl-ac88u for over18 months as the home hub could not cope with a lot of WiFi connections. It started as a good modem router but with lack of firmware updates to cure issues and still some way to go. I found it ok not like some powerful users. That amount of time is not very fair if the line stays stable for a few days?
Jason-steptoe
Message 7 of 9
Re: Broadband
Hi, I’m using a ASUS dsl-ac88u and so far since last restart it has only has 2100 FEC errors but no crc or Es errors. I suppose I will have to wait and see or contact bt for an engineers visit to do a full reset?
Keith_Beddoe
Message 8 of 9
Re: Broadband
FEC errors are normal, at least there are no CRC errors or errored seconds.
pippincp
Message 9 of 9
Re: Broadband
Wait and see, no restarts.
