Message 1 of 7
Broadband
The speed to my hub has always been fine until last weekend it was fine to my hub but very low from hub to devices. BT say the problem in in the house. Nothing has changed in my house. 2days later all was ok then last Thursday afternoon it dropped again then a few hour later it was fine. Again. Till yesterday Saturday afternoon it has dropped again. Can’t get any help from phoning BT. I’m a plus customer doing a speed check comes up unable to do technical error BT.
6 REPLIES 6
Distinguished Guru
Message 2 of 7
Re: Broadband
How are you connected to your hub wired or wireless?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 7
Re: Broadband
Connected to wireless
Message 4 of 7
Re: Broadband
Hi
I’m BT Smart customer shoul I register another complaint.
Moderator
Moderator
Message 5 of 7
Re: Broadband
@JimboAlfie can you post your router stats and run a speed test?
Message 6 of 7
Re: Broadband
I will have a go and do what you adviced but may have to wait till my son comes over I’m not very good at these things.
Many thanks
Message 7 of 7
Re: Broadband
Hi
BT have checked my line someone from India yet I signed up to BT Plus.
I’m told my speed to my hub is good and they have checked my line they say the problem is because I’m using my iPad and iPhone .
Nothing has changed in my house but BT say they can’t do anything. Not happy with BT, still waiting for my son to do tests to send to you.
