Message 1 of 5
Broadband
Over the last couple of weeks our broadband keeps dropping and then reconnecting more or less straight away. Usually starts around lunchtime, no set pattern. Usually lasts for a couple of hours and then is all okay, occasionally drops during the afternoon. Area code 01508. Thanks
4 REPLIES 4
Recognised Expert
Message 2 of 5
Re: Broadband
Seems to affect several ISPs so may well be an infrastructure problem.
Your 01508 is listed amongst others.
Log in to :
https://home.bt.com - Check service in your area
Message 3 of 5
Re: Broadband
check your landline for a dial tone  if ok then dial 17070 option 2 should be silent and best with corded phone
is it the actual broadband that is dropping - lights on hub change colour - or is it the wifi that is dropping
Message 4 of 5
Re: Broadband
Thanks for the prompt response, 01508 is listed
Message 5 of 5
Re: Broadband
Hi, line is completely silent using corded phone. Yes, lights on hub change colour. Another reply has suggested infrastructure problems in 01508? Thanks
