Rayh10
Newbie
Message 1 of 5
Bt Broadband plus speed
I have the same problem by said 32mb was all the speed the cable could handle what do you think???
4 REPLIES 4
Dean007
Recognised Expert
Message 2 of 5
Re: Bt Broadband plus didn't double my data...??
Hi @Rayh10
Thanks for posting, but I am confused by what you are asking. Are you refering to the speeds of your land line?
Rayh10
Newbie
Message 3 of 5
Sorry just upgraded to bt plus broadband still the same speed as before??
Dean007
Recognised Expert
Message 4 of 5
Hi @Rayh10
I’m sorry to say that BT Plus can only give you the speed your line can support, it doesn’t give you any additional speed. It will give you the fastest 4G network speeds local mast can give if you have BT Mobile.
What was the minimum guaranteed speed that it gave at the time of ordering
Rayh10
Newbie
Message 5 of 5
Thanks for your reply after checking my order i am getting what they said. I did expect to much i think. Thanks for your help. Rayh
