soundmagus
Message 11 of 17
Re: Bt FTTP
The address checker is down lol
Here is apicture of outside the property-ish.
Our place is over the wall where the red arrow is. (its actually furether down than it looks).
Mark
soundmagus
Message 12 of 17
Re: Bt FTTP
Hi i got an address search done finally.
pippincp
Sage
Message 13 of 17
Re: Bt FTTP
Looking at the photo you've supplied it looks like there's a CBT on the pole where they will take the fibre from and it will be an overhead cable (the same as the phone line).
Give the FTTP team a ring to order, they cannot tell you anything about the install as that is in the hands of Openreach.
0800 587 4787
soundmagus
Message 14 of 17
Re: Bt FTTP
Hi pippincp
I have already made the order hence the engineer coming out on the 28th. If its the case that it will be an overhead cable then all is well, and no excavation will be needed, which means things are A OK.
Thanks for your input.
Regards,
Mark
licquorice
Message 15 of 17
Re: Bt FTTP
As you can see from the checker result, it confirms overhead feed with no anticipated problems.
pippincp
Sage
Message 16 of 17
Re: Bt FTTP
Didn't look at that, 1 stage so yes overhead.
soundmagus
Message 17 of 17
Re: Bt FTTP
licquorice - thanks, i have had it confirmed on the phon enow also.
i dont understand why they didnt confirm this stuff initially.
iniltous - thanks for all your guidance and the link to the checker etc, you have all put our mind at rest and now we can get ready and move to our new home with much less stress and worry.
Again thank you all for you help, its very much appreciated.
Mark
