Rhyn0
Message 11 of 17
Re: Bt Infinity 2 clearly capped at 40/10. Tech support=useless
What sort of increase am I looking at with this modem?
What i'm trying to understand really is what influences the DL line IP profile speed? how is that calculated? is it fixed/set or does it vary?
And how can i find how far i am from my cabinet or whatever it's called. i tried a few searches but nothing obvious.
Thanks.
Message 12 of 17
your IP Profile is 98.6% of your connection speed (data rate ) and it only changes if the data rate changes your download can be anything up to that speed
as to cabinet distance once you know your cabinet number from the the checker the best way is to take a walk around your neighbourhood and locate the cabinet
Rhyn0
Message 13 of 17
Thanks, i'm starting to grasp all of this. Looks like i'm asking the wrong questions :D. Thanks for the patience.
So it looks like it's the data rate that interests me. I assume its a combination of physical limitations (line type, distance, interference) and "soft" limits, as in operator set limits.
What i'm trying to find out is if there's a way to check if that 40 max data rate is set by the ISP( as in BT). I assume that's quite impossible, but doesn't hurt to ask. Like, if someone forgot to change that 40 to 80 for example in a little box somewhere.
Seeing as when i DL constant to that 40 at all times, that's why i think it's limited/capped somewhat.
I've looked into geting a Huawei 612 as well, we'll see if that solves anything.
Message 14 of 17
you can see from your stats that you are not limited in speed and are on ifinity 2  your limit is more to do with distance from the street cabine and line quality not forgetting possibly G.INP
Message 15 of 17
the soft cap relates to infinity1 which has a 40mb cap down and 10mb IP profile on the upload your connection speed is 43.26mb which is at the bottom of the infinity 2 speed range
Tazz
Message 16 of 17
Call BT ask to move down to the 40/10 package and save some £££
Rhyn0
Message 17 of 17
hmm, guess i'm just unlucky then..
I'll try the 612, if not i'll downgrade to inf 1
