KevinKB
Message 1 of 9
Bt Infinity speeds dropped
For about a couple of weeks the connection speed on my broadband has dropped
Heres a speedtest result from the beginning of this month when the concection was fine :
7292125885
And now heres a result from this morning
7590296163
Here's a screenshot of the adsl speedchecker for my home phone number
bt1
And also here are my homebhub stats
Spoiler
Product name:
BT Hub 6A
Serial number:
+084319+NQ71718396
Firmware version:
SG4B1000B540
Firmware updated:
22-Apr-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
1 Days, 8 Hours 37 Minutes 28 Seconds
Data rate:
918 Kbps / 29.68 Mbps
Maximum data rate:
927 / 30351
Noise margin:
6.5 dB / 3.3 dB
Line attenuation:
31.2 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
5262 MB Uploaded / 26136 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-FGPT
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-FGPT
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
F4:6B:EF:39:99:85
Software variant:
Boot loader:
7.33.1
Another problem which I also have which may be related is whenewver I connect to my home network with my mobile phone via Wifi the connection speed on my computer whihc is connected via Ethernet slows right down. That issue started happenign arounf the same time as the connection speed issue.
8 REPLIES 8
Message 2 of 9
Re: Bt Infinity speeds dropped
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
A speed drop like that is normally caused by a disconnection of one wire, in which case, you will also not get any dial tone on your landline phone.
KevinKB
Message 3 of 9
Do I have to do this test with a corded phone ? We only seem have cordless phones
Distinguished Guru
Distinguished Guru
Message 4 of 9
Although a corded phone is better you can do it with cordless, you may get a small hum in the background.
Message 5 of 9
If @Keith_Beddoe is correct it will not matter as there will be no dial tone. Quiet line test is best with corded but if cordless may get dull hum which is ok
KevinKB
Message 6 of 9
Any phone socket is fine or should I use a specific one ?
KevinKB
Message 7 of 9
Just tried to do the test and there was no dial tone. Ringing the landline number with my mobile didnt seem to get thorugh either.
Message 8 of 9
You need to try using test socket and if still no dial tone then report phone fault to 151
Message 9 of 9
It is very important that you report it as No Dial Tone, and not as a broadband fault, as phone faults get priority, and you broadband will get better once the phone line is working again.
