10imohammed
Message 1 of 10
Bt adapter
Hello My engineer installed by infinity but he made a mistake cutting too much of the bt wire He has put an adapter to extend the wire. Does this adapter affect speeds ? Thanks
9 REPLIES 9
Message 2 of 10
Re: Bt adapter
Can you take a photo and post it up to show what you mean?
10imohammed
Message 3 of 10
Re: Bt adapter
Hello
Thank for the reply
Message 4 of 10
Re: Bt adapter
Won't affect speed at all.
10imohammed
Message 5 of 10
Re: Bt adapter
so to confirm it wont affetc my speeds because i thiught adapter slow speeds?
thanks
Message 6 of 10
Re: Bt adapter
No it won't.
It's not an adaptor as such, merely a box to allow two cables to be joined together.
Are you having speed issues?
10imohammed
Message 7 of 10
Re: Bt adapter
Speeds are amazing
getting 75 wireless
just thought ill make sure that this extender doesnt affect signal.
Message 8 of 10
Re: Bt adapter
Its just a nice neat housing where the wires are joined together, there is nothing else inside it.
Message 9 of 10
Re: Bt adapter
75 is pretty much the max you can expect to get so that in itself tells you that it doesn't affect the speed 🙂
10imohammed
Message 10 of 10
Re: Bt adapter
thanks
yh really happy with speed
