chaogege
Newbie
Message 1 of 2
Bt connection fails all this afternoon
Anyone experiencing the same problem?
Tags (1)
1 REPLY 1
Moderator-Retired
Message 2 of 2
Re: Bt connection fails all this afternoon
Some more details may be of use such as:
- which area you are in
- which exchange you are connected to
- what symptoms you are having
- whether you are connected via wired/wireless connection
etc.
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
