Jm_1
Message 1 of 3
Bt fiber
When i first got bt fiber in febuary it was fine i had 15mbps and 11 ms it was great and that was the best interet we get in our area, but after a few months it got worse and worse and it keeps going that way the download speed is now 7mbps when it used to be 15mbps and now online gaming is bad as i keep getting a loss of 70 percent and the ms keeps flying up to 2000ms our ms is so bad  loading websites everything, when we spoke to bt they jsut sent us a new hub what has done nothing is there anyway our interent can go back to how it used to be?
a link to my internet speed test
http://www.speedtest.net/result/7735524466
2 REPLIES 2
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: bt fiber has dropped so much
Can you post the connection stats from the hub.
HH6 Advanced settings/technical log.
HH5 Troubleshooting/helpdesk.
Moderator
Moderator
Message 3 of 3
Re: Bt fiber
Hi @Jm_1
Welcome and thanks for your post!
Please post the stats that @pippincp is asking for and we'll take it from there.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
