L3
Message 21 of 35
Re: Bt fibre low speeds is it fault?.
Cheers guys.
A home tech engineer sounds more like someone who sorts out a router, any wireless issues and not fault fixer for sockets, lines, cabinets, poles.
Looking at this that snr dropping going that low shouldn't speed increase
Current Rate (Kbps)Max Rate (Kbps)SNR Margin (dB)Line Attenuation (dB)Errors (Pkts)
691632397
682023129
50.7
33.722.5
117321446
imjolly
Message 22 of 35
the noise margin is dropping due to your actual speed remaining the same and your attainable constantly dropping.  you need engineer for your line
L3
Message 23 of 35
Looks like it's had some kind of drop or re sync today tp link lcp down,  leaving showtime
And came back with this
696432397
696445715
5.912.1
22.722.7
1037
L3
Message 24 of 35
Hi
I've had my smart hub 2 arrive.
Now do I stick with my TP link 9980 or go with smart hub 2.
Please guys like your feedback?.
Thanks.
pippincp
Sage
Message 25 of 35
Stick with the TP-Link IMO.
imjolly
Message 26 of 35
the last stats was best attainable speed you have posted for a while
the tplink is only single band whereas SH2 id dual band so depends on how much use you could make of the 5ghz network
L3
Message 27 of 35
Hi guys
I got home tech engineer coming this week, is it worth him coming will he fix it.
Does the max rate go up and down this much 45-46 to today' s (see below) back to 15th may max rate was 46.
Cheers guys
681632397
679729136
5.35.1
3422.6
4294965397733
pippincp
Sage
Message 28 of 35
That will be a Qube engineer to check you've set everything up correctly. He cannot access the Openreach network nor make any changes.
Welcome to BT's chocolate Teapot.
L3
Message 29 of 35
Update guys estimated time of arrival for engineer between  2 and 4.
Up until now no show  and its  nearly 4.10pm and checked the account says engineer visit complete.
Not a good service
NeilO
Moderator
Moderator
Message 30 of 35
Hi @L3 I'm really sorry the visit didn't happen that's not good at all. I know that Openreach are attempting to resolve faults on the external network without accessing customers homes but they should still be getting in touch to let you know what's happening. Are you still experiencing slow speeds?
