Guru
Message 21 of 25
Re: Bt home hub 3 Any good?
Oh I forgot you can see your Sync speed!
If you run this test here, it will tell you the sync speed under "Connection Speed" when completed the speedtest.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
Guru
Message 22 of 25
hmmm.. that test didn't complete correctly for me. Also, it talks about speed Exchange->HomeHub rather than cabinet->modem, soI'm not sure if it really will be the sync speed it gives?
Guru
Message 23 of 25
I've had experince where it won't show as well don't know why but I can confirm it's the sync I have access to my modem stats.
Guru
Message 24 of 25
Interesting, I'll keep trying. I have access to stats too, but still good to see what the options are.
Guru
Message 25 of 25
Just tested now last nights sync was 26.3Mbps, that reports 26.3Mbps though my current sync is 24.4Mbps.
Edit: I had a bRAS mismatch, restarted the PPPoE and it's now showing the 24.4Mbps sync. 🙂
