Jackie4
Message 1 of 5
Bt home hub 4 to bt smart hub upgrade charge
Hi everyone
I currently have a bt home hub 4 with fibre broadband and i have read that i can upgrade to a bt smart hub for free.
First of all do i have to pay anything for the bt smart hub
and is there a delivery charge for this?
Thank you
Jackie
4 REPLIES 4
imjolly
Message 2 of 5
Re: Bt home hub 4 to bt smart hub upgrade charge
from memory the delivery charge is £9.99
are you wanting to upgrade for a particular reason  - obviously it just the hub whereas you currently use the hub and modem  are you having problems with setup.  many would say including me - if it ain't broke don't fix it
Jackie4
Message 3 of 5
Its that when we bought the package we were given a home hub 4 which is now outdated in hardware terms. But when you buy the exact same package now they are giving you the newer smart hub. we have also had a problem with the hub before with slow speeds.
imjolly
Message 4 of 5
it is up to you but I doubt the change to the hh6/sh2 will give you any faster speed than the hh4 and the modem
if you have problems is there any line noise   dial 17070 option 2  should be silent and best with corded phone - any noise is a problem for broadband
Jackie4
Message 5 of 5
Okay thank you i will look into it
